turbos, k26/k27
Old 03-05-2003, 10:43 PM
86944turbo
86944turbo's Avatar
Post
I realize that K-27 is somewhat of a generic term for a line of KKK turbo's. 10 yrs. back I used one w/8 size hot house. The 2.5L also had HKS adj. boost and APE MAF w/ahip designed to work with the K-27, that I bought from TPC. My HKS boost gauge would read a peak hold of 20 lbs. I assumed this was through the RPM range. I was told to have a passenger watch it carefully and that it shgould drop like a rock after 5000 rpm. It did. All the way down to 13.5 lbs. on the gauge at 6900 rpm. They are pretty old (design & development) turbos. I've also been told (same guy who told me it was gonna run out of steam) that they produce a lot of back pressure, power loss. The motor had a big surge at 4000-4500, but it was deceptive. That was the torque. After 5500rpm it did not pull nearly as strong. Not much h/p. I belive the rear wheel dyno figures were in the 290-305 range. Intake manifold was also X-honed. FPR was from a 944 "s", I believe. Those APE chips always had that too rich smoke at peak torque, even after burning 2-3 new ones. Again, that was 10 yrs. back.
Old 03-05-2003, 10:51 PM
Edman951
Edman951's Avatar
Post
Don`t forget are weak wastegate.
IMO the wastegate is what make a #8 not hold boost to redline and not #8.
With a strong wastegate even the #6 can hold boost to redline.(from what i have read)
Old 03-06-2003, 12:35 AM
Matt Sheppard
Matt Sheppard's Avatar
Post
Edman951:
I guess my mistake. I sold my old set to a listee up north that had maybe a similar name (?). Ha, that must have sounded really presumptious.
I beleive your theory about the wastegate is accurate, esp. if you have an EBC, just that a #8 hot side should remain efficent through a higher CFM.
Old 03-06-2003, 12:25 PM
Dave E
Dave E's Avatar
Post
I have a K27DR from powerhaus (P.O. selection) does anyone know what the specs are? It does hold boost to redline with my Tial WG, at any setting from 15-20 psi. I haven't tried setting it any higher.
Old 03-07-2003, 06:53 AM
Danno
Danno's Avatar
Post
I haven't seen any dyno-charts of a K27DR with over 300rwhp. So that seems to indicate that it's a K27/6 variety of some sort. Also heard that quite a few of the K27DRs don't have a left-hand threaded nut on the compressor-wheel and many of them have spun off and grenaded the turbo... <img border="0" title="" alt="[Frown]" src="frown.gif" />
Old 03-07-2003, 10:44 AM
Dave E
Dave E's Avatar
Post
Thanks Danno, That's reassuring...What would you (or others) recommend for a band aid (read: budget getting low for this years upgrades) improvement for this turbo until I swap it out next year? (besides checking for proper threads) #8 hotside with a chip change? Do you make chips for K27/8 equipped cars? And if so, what is the boost threshold before the stock injectors max out? (ballpark, I know dyno runs with a wideband are required for precise determination).
Old 03-07-2003, 03:49 PM
TonyG
Rennlist Junkie Forever
TonyG's Avatar
Post
There are quite a few of cars with the K27/6 turbo that crank out over 300rwhp.
My old 951 did just over 345HP to the wheels with a K27/6.
I know several people that have done from 335HP to 345HP to the wheels on the K27/6 w/o any problems.
Old 03-07-2003, 06:20 PM
Mike B
Done With Sidepatch
Mike B's Avatar
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Dave E:
<strong>Thanks Danno, That's reassuring...What would you (or others) recommend for a band aid (read: budget getting low for this years upgrades) improvement for this turbo until I swap it out next year? (besides checking for proper threads) #8 hotside with a chip change? Do you make chips for K27/8 equipped cars? And if so, what is the boost threshold before the stock injectors max out? (ballpark, I know dyno runs with a wideband are required for precise determination).</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Good question Dave...I have a K27/8 (I believe it is an 8) too...Danno??????...and if you catch this Danno...Any idea on the cost of your wastegate conversion???
Old 03-07-2003, 10:42 PM
Danno
Danno's Avatar
Post
You've got email !!! <img border="0" alt="[bigbye]" title="" src="graemlins/xyxwave.gif" />
Old 03-08-2003, 12:00 AM
Edman951
Edman951's Avatar
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica"> I guess my mistake. </font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">No problem Matt, but i must ask why you changed to a Guru? I know their chips are probably the best,but you had the second best chips.
<img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
Old 03-08-2003, 12:57 AM
Dave E
Dave E's Avatar
Post
No I don't.
Old 03-08-2003, 04:41 PM
Silverbullet951
Silverbullet951's Avatar
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by TonyG:
<strong>There are quite a few of cars with the K27/6 turbo that crank out over 300rwhp.
I know several people that have done from 335HP to 345HP to the wheels on the K27/6 w/o any problems.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">I know a guy who hasn't refunded Ian his money. People are waiting for your response. Stop being an *** and answer us.
Quick Reply: turbos, k26/k27
