AFM Adaptor Plate for S2 SC conversion help
As part of my supercharger installation I'm trying to reuse the AFM (mainly to avoid having to convert the signal voltage). The S2 AFM has a bend for the inlet end which normally connects through to the airbox through the hole 951 intercoole pipes pass through. Here's some pics.
![Name: IMG_3953.jpg
Size: 42.3 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/585961d1322400362-afm-adaptor-plate-for-s2-sc-conversion-help-img_3953.jpg)
![Name: IMG_3954.jpg
Size: 53.6 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/585962d1322400362-afm-adaptor-plate-for-s2-sc-conversion-help-img_3954.jpg)
Is the 951 bolt pattern for this end piece the same (80x52)? The S2 has a 70mm inlet dia.
Looking to swap the inlet plate/pipe piece if possible so I can get a straight outlet. The turbo bolts to the air box, but are there readily available adaptor plates to suit - ie plate to short pipe?
Professional Hoon
I can get numbers tomorrow for you if no one else does.
go to autobarn, they have afm adapters for pod filters. not sure the bolt pattern is the same but worth a shot.
LR also have this. http://www.lindseyracing.com/LR/Parts/944AIRFILTER.html
Rainman
I got one off ebay for $3 one time, brand new CNC'd aluminum with ovaled holes for different AFMs. Look around there and you might find them. There are currently 2 on ebay that I found quickly for 944 AFM.
http://www.ebay.com/itm/Porsche-944N...item2eb97aac08
Professional Hoon
no worries!
As far as i know, i installed one on my mates nissan skyline r33 from autobarn, and just bolted straight up. I'm not sure if the bolts are the same but it was steel and i from memory it was either a 2.5" or 3" cylinder.
