My Dyno Sheet
11-11-2011, 09:04 AM
Again, This was an early dyno run. The car is running in the low 11's on the AFR gauge now. The car has 72# injectors and the bosch racing fuel pump.
I will never use this dyno again, it's too confusing. I'll get it on the dynojet this weekend.
11-11-2011, 11:47 AM
Quote:
Originally Posted by
blown 944
Some odd things going on.
Hp/tq crossing before 5250
The afrs are lean
Large tq dropoff.
I don't know the build, but it is strange regardless.
Yes. Something wrong. By definition, hp/torque equal at 5250.
-Dana
11-11-2011, 11:52 AM
Dana, On this dyno its reversed. I'm going to put it on a dynojet this weekend and see if it crosses at 5252.
11-11-2011, 01:17 PM
Just so you know, your numbers don't cross at 5250RPM...
11-11-2011, 01:22 PM
ChrisJ951
Use 4th gear instead of reverse...it works better
-Dana
11-11-2011, 01:58 PM
AddictRennlist Member
DanaT
-Dana
I was talking to a guy at the track who had his son in Ca rebuild his Pcar trany. When he got it back it had 5 reverse gears and one forward.
11-11-2011, 02:20 PM
Brian Broderick
You can just call him Mater. As in Toe-Mater without the toe.
(if you don't have kids under 10 you may not get it).
-Dana
11-11-2011, 02:49 PM
Chris very impressive numbers, I look forward to seeing what they are on a dynojet.
11-11-2011, 03:37 PM
Wow. 408 whp at 15psi. That's pretty incredible. Means over 200whp NA. That must have taken a lot of work.
11-11-2011, 03:55 PM
Which Bosch Racing fuel pump? It would be worth finding out the model and it's specs. You might not have enough pump/s for that setup.
11-11-2011, 05:19 PM
11-12-2011, 03:26 AM
ChrisJ951
Nice results!
I'm glad you got the AF ratio issue sorted out. What was causing the erratic AF readings on the dyno?
11-12-2011, 04:30 AM
ChrisJ951
Bosch 044 fuel pump.
1 of those
maybe ok on a modified 3L build but I'd be contemplating a 2nd one just in case.
11-12-2011, 06:25 AM
1 044 is OK for gasoline but not for high power E85.
11-12-2011, 06:29 AM
Yes, good point. I'm so used to everyone making the switch by now.
Going up to 3 of them soon enough.
