adding adjustable perches
Old 03-05-2002, 12:24 PM
si
si's Avatar
Post adding adjustable perches
Anyone know where You can buy some adjustable perches, ie collars which fit over the shocks, so you can wind the suspension up and down?
Cheers Si.
`91 951s silver and blue lther.
Old 03-05-2002, 08:07 PM
TCarrera
TCarrera's Avatar
Post
Si,
I don't believe there is anything out there that will work with the stock shocks. You are going to have to buy some struts with that design incorporated into them. There are several good choices out there, from mild to wild. Wild = $$$$
We are a Pro Trac dealer if you want to go to the wild side, these are race only components.
Good luck,
Mike at LR
Old 03-06-2002, 11:26 AM
hrk
hrk's Avatar
Post
Paragon products sells a kit with your choice of spring rate.
Check their website.
hrk
Quick Reply: adding adjustable perches
