Just about Complete
#63
Update on Turbo
I had a buddy add a second groove to my turbine shaft so now I have two oil rings on my HX35 shaft, I Found a factory compressor housing that had the anti surge built into it and installed it and all is good!!! No surging at all, no oil smoke at all, everything is good to go!
#66
#67
Here is a picture of the test shaft, Thanks SID, (Shaft has stretched threads and could not be used) But the good shaft took the groove and it ended up in the perfect spot!!! No Oil problems! I also had to build an aluminum MAF holder because I finally broke all of the ports off of the plastic one
#69
#70
That was a slow start but if you can see the rmp at all it shows it start to build at 3k, 5psi right away and will achieve 20 before you have to shift! I will measure crossover pressure as soon as I get it off the ground to pull the cap off the pipe!
#72
Do you find that you've lost any low end torque with that modded intake? That's a Rogue MAF right?
I imagine anything lost on an otherwise stock car with the intake modded, it would be slower down low, with no Rogue MAF.
#74
Passed Emissions on the first try!!
HC Readings 1.9788 Limit 2.5
CO 16.37 20.0
CO2 352.54
NOX 1.44 4.00
Rogue is the way to go,, I did put a high flow race cat on it and it almost did not pass visual inspection. The Test Center manger told me that if it did not pass the first try I would have to put am OEM cat on it for emissions........ but it passed so phew
Now this crappy snow storm closed the DMV so no plates till Monday
CO 16.37 20.0
CO2 352.54
NOX 1.44 4.00
