Tial Wastegate Install
There are two vacuum nipple fittings, one on the top, and one on the side. Which do I run the line to the intercooler pipe? What is the other one for?
Will check mine when I go home, from memory the side port is the boost line from the intercooler and the top vacuum connects to the out side of the boost controller.
Just ordered a Tial 46mm today from SFR, thanks Tim. Tim explained that the banjo bolt line goes to the in on the MBC and has a tee on it to the side port of the Tial. The out line from the MBC goes to the top of the wastegate. Which Tial did you get?
