next upgrade
next upgrade
alright i think im ready for my next upgrade.
i have a 1987 951 49,000 miles/chips/lbe/factory suspension upgrade-koni's.
please i need your input. what's next ? looking for some more h.p. without burning too much $$$
thanks!
<img src="graemlins/drink.gif" border="0" alt="[cherrsagai]" />
thanks!
Also a 3-bar FPR ($40-50) will let you adjust the LBE to give you 15psi of boost. I think the LBE comes pre-set to give stock levels of boost around 11psi or so.
test pipe !
which part of the exhaust does it fit?
will i pass inspection with it ?
how many inch do you reccomend ?
will i gain any hp ?
thanks
v-tach
thanks
v-tach
danno
FPR ?
SORRY !
can you tell me what it stands for and what it exactly it does ?
i think i could adjust the settings on my LBE.
THANKS
V-TAC
FPR ?
SORRY !
THANKS
V-TAC
Fuel Pressure Regualator, controlls how much fuel is sent to the injectors. When you increase boost you must in many cases also increase the amount of fuel sent to engine or else you car will run lean which is BAD
[quote]test pipe !
thanks
v-tach <hr></blockquote>
Test pipe = cat replacement pipe
I do not live in a state with inspecions, but I understand that the more mods you make, the harder it is to pass, so be careful.
thanks
