Good Idea to replace valve guides with Head Gasket?
Hey guys, I have a stock 1986 with 100k miles. Running strong but I think I might replace the head gasket before I add a little more power. Is it a good idea to replace the valve guides while in there on a 100k mile engine? Will have the head decked as well.
btw, I did exactly that with mine about a year ago and it didn't need much at all.
Lindsey has a nice rebuilt gone through head with 5 angle valve job, new valve guides, and some porting and polishing for about $700 with a core. That seems like a pretty good deal. Is there anyone else selling nice heads for around that much?
ya' can't go wrong there!
Rocket Scientist
You can find someone local to you that'll do it for much cheaper. Also, no shipping risk.
Basic Sponsor
Small Business Partner
If this is the stock head-gasket, then the webbing is deteriorated, and will not hold-up well to increased power-output.
Don't take the head off if you don't have a problem. Plan your boost mods correctly and spend that head & gasket money on appropriate chips and fuel mods to handle the extra boost. What are you planning to do to add boost?
Vitesse is near you, you should look at his chips & MAF w/v-flex or an M-Tune setup from Rogue.
+1, if I had it to do again, I would have replaced my stock head gasket when I put in the new turbo. It started leaked soon after and it was very deteriorated.
