944 vs. 951 heads
I have numerous 944 heads and trying to tell the difference from a 951 head. I assume in my collection I have a 951 head, but am uncertain...thanks...
Yes, if your head is rebuilt it's good to make sure the check valve is working and not full of swarf or glass beads. And that it is actually installed, for that matter.
Yes, the check valve in the turbo heads vs the na heads has a tighter opening so that oil pressure is built up in the crankshaft drive and turbocharger before filling the camshaft housing.
The other differences according to Information Technik are as follows:
1. Cast-in thermal insulating ceramic exhaust ports
2. Exhaust valve guides which are longer and made of a different material
3. Valve seat inserts are made of a material with better heat-proofing properties
4. Valve seat width for exhaust has been changed from 2.0 mm to 2.5 mm.
5. Intake valves have a circular journal
6. Exhaust valve head is completely flat
7. Exhaust valves parttially filled with sodium
8. Valve spring has an installed force that is 20% higher
9. Valve spring length is 58 mm for turbo and 52 mm for na
9. The exhaust valve springs are pre-loaded to 40.0 mm for turbo 41.0 mm for na.
Also, you can use a turbo head gasket on an na, but not the other way around.
Quite a few differences really. I have heard of guys using the na head, but I would try to use the turbo head on a turbo motor if possible.
