Stock boost level?
2nd Gear
Stock boost level?
Well I sold my 87 951 with 194k on it, and purchased a 87 951 with only 44k on it. Beautiful car! Anyways my previous car had a HR Stage 3 MAF, Chips, and Manual boost controller. I ran the old car at 14.5psi and the head gasket blew, what could have caused this? Also what is the stock boost pressure on a 951, is it 9psi? Should I install a widefire and get my head o-ringed before i put all these items on my new car?
Dan
Dan
While I have seen various numbers tossed around, I believe the 951 stock was .65 bar, so 9.56 psi. The S was .75 bar.
Plenty of people, myself included, are running close to 1 bar, like .95, with no head gasket upgrade and no problems. I would say to leave your new car's head as is if you are going to stay under 14.7 psi.
Head gasket failures are, unfortunatey, a result of a mixture problem, not a pressure problem
I know a guy that runs 23lbs of boost on an OE style gasket. As long as he keeps it close to that magical 12.5:1, he wont have a problem
I agree w/ Luke, it's a mixture problem. Currently I run 18 psi, but have sometimes dialed up 20 psi. All this on a stock block w/ stock head gasket. I keep an eye on my A/F mixture and it's always safe. My car is set up w/ the Autothority MAF which includes their chips. They are know to run on the rich side anyway.
