Question on Alternator duct
09-29-2011 | 10:09 PM
Installed the cooling duct after work today, what a pain.
Is there supposed to be an insert in the gap at the top of the shroud were the wires pass through?
Steve
09-29-2011 | 10:49 PM
Addict Lifetime Rennlist Member
Yes, there is a rubber plug that fits in the channel where the wires go into the duct at the top of the alternator.
09-30-2011 | 04:18 PM
This is what it looks like. Ignore the "modified" (removed) plastic ears on the alternator shroud... had to make room for the bigger turbo:
09-30-2011 | 05:58 PM
Thanks for the photo.
Looks like when I get one, I will be cutting a slit in it to install. Because i sure dont plan to pull the duct off to slip it onto the cable.
Steve
