new motor cuts out @3000rpm (FIXED!!)
didnt get much from the shop....i would have to trailer it up to him to get any real help. i would in a heart beat, but they are so busy at this time of year...putting cars to bed for the winter, etc.
fixed the oil leak today.
unplugged the tps and it revved up past 3000rpm once...ok, its the tps!!
put the new one on...wouldnt rev past 3000 again...put the old one back on and the same. i was happy for a split second.
Before it detonated last time, it revved up fine and the AFRs were almost perfect....now with the same set up and parts, it wont rev past 3000(back fires and cuts out) and the AFRs are way too rich. at idle its around high 15s to 17s, bring the revs up to the 2000s and its around the 13s.
checked the plugs...wet with fuel...some carbon.
when i took it for a short ride down the street the day after it started, it was the same...very rich and any load up to the 3000rpm and the AFRs are in the 12s.
thanks for any help/ideas,
frustrated adam
frustrated adam
I would recommend checking any wiring/splicing that has been done for any of your mods. I had a severe rich condition for a while and it turned out to be poor splices in the MAF harness. Also, as for the ground to the balance shaft housing, anywhere that is a good ground (electrically) should work fine. Use a DMM to test for resistance between the spot you've grounded the MAF and the negative terminal of the battery... there should be almost none. If there's more than almost none, then it's not a good ground.
Are you sure that you don't have any vacuum leaks? You're lean at idle and rich under load, so something isn't right.. What vacuum do you pull at warm idle?
Can you data log? What happens to the AFR's when it cuts out? Does it go very lean like the injectors are cut? Or does it go very rich, like it's flooding? Does it cut out at 3k RPM only under load, or will it do it in the driveway?
will check the ground resistance and maf wiring volts in and out tomorrow.
today dave from LR helped me sort out a couple vac lines that i had wrong, but it was to do with the heater...so had no effect on this frustrating problem.
not sure what you mean "what vacuum do you pull at warm idle". is there a test for this?
when it cuts out it goes really lean...17s- off the AFR gauge. at idle its in the 16s-high 17s
it cuts out only when under load...in the garage or on the street.
by load i mean giving it gas(1/4 throttle)...haven't been able to get into boost yet.
pretty well checked all the vacuum hoses thoroughly....they are all new hoses too.
hope this helps in some way to get to the bottom of this.
adam
adam
EDIT: The word 'timing' also pops into my head too for some reason...
Adam, I replied to your emails last week. It sounds that you have the rev-limit or overboost set incorrectly (or you have a short in a wire). Last week i emailed you a list of things to check, but didn't hear back from you to know if you had the time to address the list of items. (I'm still away with limited internet access, maybe I missed it.).
Just emailed you a couple of things to try/check. But from your description, it sounds that the user limits are set incorrectly OR the wiring is not functional (1 wire to check as per my instructions).
![](http://i1091.photobucket.com/albums/i397/chip18sw/Stuff/homer_doh.gif)
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Actually Adam can set overboost, overload, rev-limit or Air temp/Eng Temp. Any of the 4 values if set incorrectly will cause a shutdown. The shutdown kicks in over a certain RPM and a minimal load (outside of limp mode area, which was designed to allow the driver to run at low RPM and low LOAD which comes it handy when something like this happens).
A failed MAP sensor will generate a faulty signal causing the shutdown... Just emailed Adam a workaround to eliminate user errors (or faulty sensors).
Hopefully when I check back in a few days he'll have it resolved. He purchased the components used, he wasn't even aware of having a PB. So he has some readings to do.
Actually Adam can set overboost, overload, rev-limit or Air temp/Eng Temp. Any of the 4 values if set incorrectly will cause a shutdown. The shutdown kicks in over a certain RPM and a minimal load (outside of limp mode area, which was designed to allow the driver to run at low RPM and low LOAD which comes in handy when something like this happens).
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
![manual](https://rennlist.com/forums/graemlins/rtfm.gif)
im going to try unplugging the PB or change the chip to a setting that does not use the PB settings....will post later today.
also...talked to the shop that originally set my car up....he said bring it in next week! if i dont sort it out by next week, im pretty confident he will get me up and running.
john has been a big help with trying to get me up and running...i think i might have a better idea how to use the software. and still....he wont charge me anything.... and i think he is a good guy anyway. LOL
adam
adam
got it!!!
PB has wrong settings....unplugged the PB and its all good now.john is going to help set up the PB when he has time.
not so frustrated....quite happy now.
thanks everyone for all the help and advice...again...this forum is a wealth of information and a must for any 951 owners!!
adam
adam
