CLOCKWISE OR COUNTERCLOCKWISE?
If you're facing the front of our motors, which way do the crank pulleys turn? Silly question I guess but I need to know. I'm determining the magnet location for my SDS install. Thanks,
Russ.
Russ.
you can find this out if you turn the engine without plugs and see the firing order of the cylinders (pistons)
The firing order is on the head.
or just take teh plugs out and put the wire conectors back. if the come out in the right order whan you turn the engine you are sure that you chosed teh right decision ;-)
Konstantin
Konstantin
