Stock 88' turbo S chips Or timing chip
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Have you considered custom K27 chips. I know that when I got my k27/8 from Powerhaus they really pushed the Autothority mass flow with custom k27 chips. I went with it. I can't say I was unhappy with the performance. I was true plug and play as the combo was designed for the k27/8 with 3bar regulator. The execution did leave a little to be desired with fit and quality of the jpipe.
I guess I just expect a lot for 1700.00 investment! Maybe a bracket so the cone filter doesn't flop around? Mine is on the shelf as I am going with different turbo similiar to what Paul did. I have another Rennlister who is interested in the setup, but if he passes can you let you know. Definatly not the cheapest set up but it works.
![](http://gallery.alloutdoorschat.com/hk23e/Autothority%20Mass%20Flow%20with%20K27%20Chips.jpg)
p951s,
What part of VA are you in? I am in Richmond and have plenty of chips/computers you could try if you think that might help you troubleshoot the problem. You can come by and just plug one of my computer boards in if you like. I have some with stock chips, stage 2 chips, custom chips, etc.
p951 i have some suggestions DO you have stock injectors ? even with a 3 bar you wont have enough fuel for your mods.also maybe your timing belt is off a tooth check it.and last but least are you shure your hearing knock? a number two rod bearing going bad sounds eerily like knock under mild boost.
