Refresh951's Fall Project
Old 09-04-2011, 09:21 PM
refresh951
refresh951's Avatar
Default Refresh951's Fall Project
The 951 was pretty much maxed out at 247 rwhp, 323 ft-lbs torque. This was with the K26/6, modified A-Tune, E85, Tial 38, and 18 psi. Drove it a lot this summer and was happy but because I HAVE A DISEASE it was not good enough.
I bought a DBB TO4E .50 trim garrett turbo with a replica KKK#8 turbine housing from a fellow lister. My goal is to produce around 325 rwhp with good torque without sacrificing to much of the bottom end performance. My hope is that this turbo along with my S2 AOT tranny (3.875 vs 3.375 ring and pinion) will make a really fun street car.
I am also upgrading from the A-Tune to the M-tune and will be going to the dyno sometime before the end of September.
Old 09-04-2011, 09:48 PM
carlege
carlege's Avatar
Looks good shawn.
Old 09-04-2011, 09:50 PM
blown 944
blown 944's Avatar
Nice choice (s)
Old 09-04-2011, 09:51 PM
zerMATT951
zerMATT951's Avatar
Awesome! I'm going to save my pennies and tackle something like this next fall.
I just put all of my coolant hoses and coolant crossover pipe back in today, then got the M-Tune pipe installed. That thing is TIGHT with a 26/6. Do you know if there are any clearance issues with the tree pipe with a larger turbo inlet?
Old 09-04-2011, 10:18 PM
refresh951
refresh951's Avatar
I know a few listers have installed the M-Tune with the larger turbo inlet. I heard it is tight but it fits. My old LR MAF was really tight also. Just not a lot of room to work with in there. My M-Tune has not arrived yet but when it does I will post some pics.
By the way, love your project thread.
Old 09-04-2011, 10:26 PM
s14kev
s14kev's Avatar
I just did this too. All came together finally last month. Garrett T3/4r DBB w/ 50 trim compressor, stg 3 turbine, #10 hot housing, 3" downpipe, 4" exhaust, 72lb injectors, M-tune. I did a bunch of other stuff while in there also like having all the coolant and hard lines, brackets, heatshields yellow zinc plated; installing a nissan quest alternator and braided fuel lines etc.
Josh has been awesome with his product support for M-tune. I can't speak more highly of his product or customer service. You will enjoy the setup.
I still wish it made more power however....
Old 09-04-2011, 10:37 PM
refresh951
refresh951's Avatar
Completely agree about Rogue, I have worked with him on my A-Tune and E85 modified A-Tune and been a very satisfied customer.
That looks great. Have you been to the dyno? What kind of power did you see?
Old 09-04-2011, 11:38 PM
Josh B
Josh B's Avatar
Sweet!
Old 09-04-2011, 11:52 PM
blown 944
blown 944's Avatar
Put it on race fuel or e85 and turn up the boost. That combo should make great power!!
Old 09-05-2011, 12:40 AM
s14kev
s14kev's Avatar
M-tune fits fine with 3inch compressor inlet. Can maintain the stock headlight bracket without fouling on the air filter as well. Nissan quest alternator is easy to do, very cheap ($120 new), makes everything look much cleaner and gives a huge amount of clearance. I would hate to do any larger turbo install without it.
I have been meaning to put a thread together about my build but here is another picture. Don't really want to hijack refresh951's thread.
Old 09-05-2011, 12:44 AM
s14kev
s14kev's Avatar
Yes. That is planned. Have been ironing out some issues with the tune for just 93 octane before trying E85. Still not convinced that I will be happy with how much power it's making though. I guess I was spoiled with my last project car.
Also I somehow I keep pulling bits off the car. Right now the dash and instrument cluster is apart..
Old 09-05-2011, 01:14 AM
refresh951
refresh951's Avatar
No worries. I appreciate your info and pics. Feel free to post anything you think that might be helpful.
Old 09-05-2011, 06:05 AM
Paulyy
Professional Hoon
Paulyy's Avatar
that turbo will be perfect for your goal, i wouldn't be suprised if it spooled slightly quicker then the 26/6 with the #8 hot side and a 3D Timing map @ WOT
Cannot wait to see the end result!
Old 09-05-2011, 06:02 PM
alxdgr8
alxdgr8's Avatar
Looks very similar to mine T04E and AOT trans. Even with the 26/6 the AOT is a great mod for the car.
Old 09-06-2011, 11:28 PM
refresh951
refresh951's Avatar
Alex,
I have Rob's AOT and his TO4E turbo. When do you expect to have your car running? I really like the AOT. I have been running it with the K26/6 for a couple months now and love how it keeps the car naturally at higher RPM's in the lower gears.
Quick Reply: Refresh951's Fall Project
