alot of left to right play in shifter when in gear
There's a bolt back at the transmission that you can see from the driver's side, easy with the wheel off that can work it's way loose and that might just need tightening. It has a machined tip to fit into a hole in the rod that extends from the shifter to the trans. WHen it's loose the shifter will have side to side play.
Basic Sponsor
This worked great when the shift rod was worn...
http://www.dietersmotorsports.com/tech/tech-july-03.htm
Had the benefit of Mr. Grosekemper doing the repair personally for me since he's here in S.D.
thanks for the help i did pull the shifter boot off and the plastic bushing was screwed so I made a aluminum bushing on the lathe. came out mint and so tight now.
