Passed CA Smog with Vitesse set up !!
Clean? Just being "clean" is no where near good enough. It has to be plated, polished, sealed, clear-coated and waxed to go on Ed's car. And that's before he adjusts the fasteners for proper feng shui. Seriously, when he finally breaks down and posts a picture or two, you will be floored. The full nature of his pysychosis cannot be appreciated without some pictures, which is why I suspect he is so reluctant to post them. Of course, I say they deserve their own thread, because they WILL generate discussion....AMONGST PSYCHIATRISTS EVERYWHERE!
There. I fixed it for ya!
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
He was a very very nice Vietnamese guy. When I opened the hood for him to inspect, he said" WOW", this looks very different, as he was squinting !! He said, "That doesn't look stock", pointing to the intake manifold. I told him indeed it was .. it was just polished as was the rest of the crap under that hood
BTW.... I told Tom there is no freakin way I am doing any more plating, when I pull that stuff off ..
I really am at the end of my rope .. and it was never a long rope to begin with
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Jeezz Tom with that intro ... I am going to have a hard time living up to that
But I will try
The sticker on the hood list all the required equipment, if the AFM is on there then it's required.
In truth I think he was more focused on whether the car was going to pass the emissions test, than the visual part ... If you can't pass the smog test then your toast
They lift the hood and see a turbo on a car that never had one and your done! Unless it's a carb certified on that motor...Good luck with that!
I think he never saw a 951 maybe though it was a weird 944 N/A or something? On my 944 N/A the guy went to check the timing and I told him where the mark was and he said "I'm sure it's good!"
My friend always took the MAF off when he did smog (San Jose) but it does show that the selth kits would work out OK.
I don't know? I was a smog tech there so that's how I kept my modded 22r Toyota on the road, it was 2000ppm hc's at idle and that was with a cat! Yeah a bit much but I was young then!
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
They don't call it the land of fruit and nuts for nothin'
Nope, you fail the visual you don't get to the emissions test! Turbo Tercels run under ground out there.
I really can't get into it, but what I was trying to say was the hurdle I had to deal with, was primary passing the smog test...
As a MAF sensor is functionally an Air Flow Meter, I would be interested to hear which points they put forward to refuse cars they deem illegal because the AFM doesn't look like what they expect it to look like.
Hi Eddie, congratulations on getting the car running and back on the road.
I must admit, I miss-calculated how long it'll take you to get the 951 running. I was thinking 10-15, but you did it under 7 years.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Drop me a note once you turn up the boost to 15psi; hopefully someone can take a picture of the grin on your face after a spirited drive.
I hear the car looks awesome, post a few pictures.
Cause it sounds like you caught a break! Just don't want anyone to have a cow if they go in with a MAF and fail for it.
I did smog in Mountain View in the early 90's. 951's are actually pretty easy to pass chipped or stanalone as long as they look stock and the basic's are there.
On Tercelonline, I'm the resident wipe blanket for guys that want to do the
4efte Turbo swap. Not a legal swap, engine not availble in US = instant fail!
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Again Congraulations!
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
You would be wasting your time... The simple reason is THEY ARE FREAKIN" NUTS .. I should post the link to their rules and regulations ... It would confirm all one's thoughts as to why big government regulation ( well most of it! ) is pure bull****
I started with a relatively recent sports car and ended with what will soon be a classic
Sorry guy I was'nt trying to argue with you. Just answering general question,
4efte Turbo swap. Not a legal swap, engine not availble in US = instant fail!![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Again Congraulations!![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
You are completely correct, and your point is well taken ... as I don't want to mislead anyone as well, thinking they will pass the visual with a MAF in place.
Thanks Guys
Best regards
Ed
