Idea: dual 3" exhaust tips ?
Professional Hoon
What do you guys think about this idea?
i have a full 3" exhaust and im going to dump the wastegate out the rear and came up with this idea.
basically the wastegate will dump into a 2.5" pipe all the way to the muffler then turn into 3" so it looks the rear will look like something that came out of the factory but larger.
after the 2x 45 degree bends is a 3"-2.5" reducer to go all the way back
maybe slash cut the tips also? and polished
these are just off-cuts just to see how it will look.
Professional Hoon
That dosnt look bad
neither was i to be honest. i never really liked having the wastegate dumped right under the car. because i've got a 2.5" tube in my backyard i thought id use that and i was going to go all the way but then i seen i have left over 3" bends and just use them up and pretty much came up with the idea of having dual 3" tips instad of 1 thats 2.5"
if it sounds that bad when its dumped to the back i might put a hotdog or small resonator on it
The orange car on Lindseys main page has this setup, it seems like they might use a smaller pipe than 3". 2.5" is probably more than enough. I think it's only 2" at the pipe that dumps out the bottom of the WG.
