Which is Low Pressure side of A/C?
Adding r12. Both valves are next to each other at driver wheel well. One valve is on thick pipe, one is on thinner pipe.
Which is low pressure side? (my system is low so can't tell the obvious way).
Thanks! - Mark
Thanks! - Mark
Err...on my car the low pressure side is under the car...driver side.
By the swaybar kind of...you can get to it without removing anything and with the car on the ground.
Thanks guys! I'll put my new IMACA (EPA) certification and Freon R12 to the test tonight. Gonna try to top up the Garage Queen in case warm weather ever hits Pennsylvania.
Thanks again for all the support. Now all I have to do is figure out an easy way to "jump" the Compressor clutch. Looks like there is a switch on the Evaporator that may be the low pressure safety cutoff (??).
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by MarkBytes:
<strong>Now all I have to do is figure out an easy way to "jump" the Compressor clutch. Looks like there is a switch on the Evaporator that may be the low pressure safety cutoff (??).</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Mark, is that so you can run the compressor and pump/pull the new R12 into the system?
I'm just an HVAC dummy trying to understand.
Ron
Ron
Just put some R12 into the system (low side) with the AC switch turned on, it will cut in as soon as it sees a little more preasure. If you bypass the low preasure switch, you will turn on the compressor with too little fluid, not a good thing.
Project completed!
Added one can of R12, raised pressur in the system enuf to start compressor. Thermometer in dash vent registers 45 degrees.
If I still have "pressure" tomorrow, I'll be one happ camper. Bring on the sunshine!!!!!
For your info:
IMACA Certification = $15 1 hour read & test
1 Can freon - $20 (ebay)
1 R12 install hose kit - $4 (pep boys)
Install time on car = 1 hour
For your info:
