wastegate tie in or dumped? need solid info
#61
I don't think boost pressure will be impacted by this. The wastegate signal comes from the intake side. I think any change in pressure in the system pushing on the valve in the gate would be overwhelmed by the internals of the wastegate.
#62
Yep not a problem. It takes me about 10 min to swap between the 2. I will do it back to back. I have some thick oven mitts if the pipe is warm ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
The setup I have is pretty slick to work on. 2 studs and 1 clamp to take apart. Slide on the wastegate tie in muffler and pipe from wastegate to tie in muffler...zip up clamps and put nuts on the 2 studs and done.
I do have lots of other stuff to do this year but if things go well then yes I should get it done.
The problem is with this, is you need to dyno it, then the same day modify it and dyno it again all on that one day, because weather.
When i do it, i'll get my maf voltage and compair it and see if there's any difference. And also, if by boost drops, i know i've gained back pressure.
#63
Professional Hoon
