fuel line fire!
#31
Aeroquip hose. It's for airplanes. FAR higher standards than the automotive world. I'll be installing mine in the next few days.
FWIW, I had what seemed to be a fairly mild fire, and it wasn't until I pulled the engine that I found half of the damage...
#33
I replaced all 3 of mine, and the date on the jumper was in 1985!
The hoses on my plane have bands around them with the hose assy # and the born on date. This would make replacement decision easier for future owners on these cars, if the hose shop has the capability.
#38
#39
Good Idea!
#40
Ok so deleted fuel damper and now im having boost issue. I can only get 10 psi before bov opens. Where should vacuum to bov come from? Ill double check lines to wastegate.
#41
Defending the Border
Rest In Peace
Rest In Peace
Made mine, did a thread on them with BAT fittings, never looked back.
When you've put out a 928 fire at a gas station in the middle of BFE, CO, you learn a new respect for these lines.
Connect the new ones in the fender, not bay.
#43
I bought a halon fire bottle and rennbay fuel hoses when I had the 944. I fortunately never had to use the bottle but they won't corrode like the dry chem ones will if I'm not mistaken.
#44
yeah. i used to think that my car would never go up in flames. boy was i wrong. i bought larts fuel line kit that connect in the fender. i just did a quick fix with stuff i had lying around to see how bad the damage was.
