Getting close! - IT'S ALIVE! (9/9/11)
#31
Well it's not the banjo bolt, it's (I hope) where the other end connects at the bottom of the engine mount. I really hope it's not the bottom turbo seal (I replaced it with the turbo). Will look more into it tomorrow maybe, it's been pretty toasty to be in the garage in coveralls.
#35
#37
Good to know! Gonna pull the whole thing off tomorrow and inspect it. Hope it's just an o-ring.
#38
Took a family photo this past weekend at the new place. Got them all washed off after they had a few inches of dust on them. Still have to finish unpacking and such before I can tear back into it and fix my oil leak. Once that's done I need to get the Audi in the garage and pull the trans.
![](http://i14.photobucket.com/albums/a303/alxdgr8/2011-10-01_15-52-06_499.jpg)
#41
Looks good, Alex!
#42
#43
If you read RCW 46.16.240, it states that:
"In cases where the body construction of the vehicle is such that compliance with this section is impossible, permission to deviate therefrom may be granted by the state patrol."
I've been told by a few local cops that this basically means that, if there aren't holes in your bumper, or a bracket for the plate, you don't have to run one... Your choice, but I'm pretty sure that, if there's "nowhere to put one" you don't have to have one.
#44
Time for a little update since it's been a while...
Fixed the oil leak, was the oil return o-ring (which was new), so I purchased a T3 gasket and it sealed it right up. Replaced the belts and rollers trying to solve a squeal, but it's still there....pretty sure I've traced it down to the waterpump. So I'll be removing everything and doing the belts for the 3rd time this month! I am also pretty sure my cam tower gasket is leaking too. I've degreased the exhaust manifolds but they still smoke when the car is running so I'm guessing new oil is getting to them somehow. Pretty sure my ISV is leaking under pressure too as I pressure tested to 15psi and can hear a leak under the intake mani. Pulled it off and tightened once already, but it's still there. I pull about 10-12mmHg vacuum on a cold start. So the intake mani is probably coming off once again to replace the ISV. Still need to relocate the AIT sensor to post-IC. Getting some smoke at idle too, but hopefully improved vacuum on the AOS will cure that. I have a catchcan installed but it's a sealed one and is routed to the intake pipe. Will have to experiment with that and take it out and see if it makes a difference. I sure hope it's not the turbo itself. Other than that, the car starts up decently and revs out pretty well with the tune it's got. Once I get the car in 100% condition I'll schedule a tuning session with Bob Boyer and see what it can do!
#45
Oh, and I found out the car was indeed running on 3 cylinders in the video posted. Had a dead NGK spark plug straight out of the box, replaced it and it fired up and ran much smoother.
