best bang for your buck( gur chips installed)
it's been two weeks now since i installed the guru chip set. i previously had the arc2 chips in it and it ran way too rich, idles erratically, smokes when boost kicks in or wot.
with the guru chips, all these ailments have been aleviated "plus" i get better response. then i installed the shims," wow" first test run, it actually put my head back in the head rest.
for the amount of hard earned money spent, guru chips are the way to go. plus all the technical support that is readily available from this knowledgeable person.
from now on all further mods will be from Danno, nice guy, knowledgeable and not just out there to make the quick buck, some actually that i consider a tuner. always trying to make things better and available for all levels of income.
so the stereo type that you need to be rich to own a Porsche is out the window, you just need more ppl like Danno to be around and actually care about his and others passion.
to danno, thanks a lot and looking forward to do more business with you soon as i save more.
next up grade will be the digital a/f gauge.
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica"> what would anyone suggest be the next upgrade without breaking bank?
</font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">About what do you want to spend ? <img border="0" alt="[burnout]" title="" src="graemlins/burnout.gif" />
OK guys...go ahead...rub it in! While I'm waiting for my GURU chips to arrive, just make me suffer!!
OH no, I don't want you to feel guilty or anything...that's ok...
Seriously Carl, I'm very glad to hear that the chips worked out well for you. Makes me even more anxious to get mine installed!
i'm scared that i might mess up something if i put it to the 15 psi, it's a daily driver and can't afford to do major work on it. if the occassion calls for 15 then i'll set it up then.
but iaw danno it's safe to do so, but i'm still sceptical as this is my first p-car and i'd rather run it below rather than blow something up and have to garage it till i get the funds together.
david, somewhere between 300-400 bucks. but i think i may need to do a belt tension first, nd to save on the tool.
bjorn, i think sway bars or something in the suspension too as i have a lot of body roll in corners.
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica"> david, somewhere between 300-400 bucks. but i think i may need to do a belt tension first, nd to save on the tool.
bjorn, i think sway bars or something in the suspension too as i have a lot of body roll in corners </font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">The 968 MO30 sways are a great choice, Koni yellow shocks would be another option and together you will reduce the body roll a tremendous amount.
carl,
My car was running 12psi bone stock...crank it up a little...14psi couldn't hurt. You can control the boost with your right foot also you know. <img border="0" title="" alt="[Wink]" src="wink.gif" />
At 12psi you may be too rich...
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by smkn951:
<strong>thanks adrial, i'll crank it up a couple of turns and go for a run see.fp is set at 40 psi right now with the vacuum line disconnected any adj. needed more /less?</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">The guru chips I have require 3bar fuel pressure which should be 45psi with the line disconnected. When I connect the line, the pressure goes down to about 38psi. I'd personally use the proper fuel pressure and 15 psi boost as that is how the chips were designed.
I just installed the Guru chips/FPR/Reliaboost kit on my otherwise stock (but shimmed) 86 951. I have no hesitation or stumbling, just gobs of power (14 psi max). Maybe, just maybe, I have a little more lag (had a LBE before the guru kit) but maybe not. Last night, I went out and thrashed it good and I could find nothing to complain about. Just posting a data point, YMMV.
Deitz
Deitz
