LS6 Project
#151
Outstanding work on the conversion!! While having completed the conversion myself earlier this year, I have yet to take it to the track (been killing cones in Solo). Looking forward to seeing your track video!
#155
#156
Looking great.
I ran my car at Barber yesterday. It ran great for four laps each session and then overheated (water temp at 240+). Looks like my 951 radiator, which was just cleaned and pressure tested is not up to the task. Of course, it was 103o yesterday, so it was stressed.
#157
Need some help.
Recommendations for a source on throttle cable bracket.
The power steering rack does not fit, not even close. Anyone deal with this? Did you fabricate brackets, photos?
#158
Throttle cable source
Lokar makes a universal throttle cable you can buy it from Summit, Speedway or Jegs it is what RH sells but it will be a lot less expensive from one of the vendors listed. They offer 2 lengths get the shorter one I think it is 30".
#160
Disaster: car looks great and spotless.
I also love that accusump location!!
I have the RH radiator and I was sustaining 230-240 at the track (ecr) this weekend. But thats about the same temps my C5 ls6 ran at the track. I may try to work some ducting though.
Overall my engine was running great...until i snapped a front hub.
Looking great.
#161
Also, how hot is too hot for these engines?
#162
I haven't pulled the hub yet. I have some 87+ hubs and spindles sitting in my apartment, guess I have to install them now lol.
I'd say 250 is pushing it. On the c5 I had the first fan didn't even turn on until 230, these engines were originally made to run hot due to emissions.
#163
And I don't understand about the power steering rack? Are you using the RH pan, the factory rack and the factory cross member? I need more info. My setup is bone stock except that I modified the high pressure line to accept an AN fitting from the pump. Stock everything else.
TonyG
#164
