Man - someone got a heck of a deal on this turbo!
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I haven’t seen the carnage but from the description of the break (just below the wrist pin) it sounds like rod fatigue. The engine had stock forged rods and 25,000 miles and almost 10 years since the build. I have seen the rate of stock rods failing going up in the last couple of years, after all the ‘youngest’ 944 rod is over 21 years old now.
I use to be ‘OK’ with reconditioned and magnafluxed rods in a track car….I may have to rethink that. Magnafluxing will catch a crack that has already started but it won’t help with fatigue just before the crack starts.
Could be worse – it could have been on the Cross Bronx Expressway!
Engine lead
Hey Josh, If you think you will have a motor for $1750, what are the details on that engine? Can you give me a call or send me an email mrcbx@@att.net (remove one @)
Other rods
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
BTW – the shop in Long Island sent some pics and that jogged my memory a bit – the rods in the engine were the original 1989 turbo rods (some might call it a ‘Turbo S’ but since it was the only turbo offered that year the factory stopped calling it an ‘S’). Now I remember that the rods in that engine were the cast rods and at the time the option for aftermarket rods was not taken and the though was that if Porsche used these rods in a ‘Turbo S’ then they were good enough for this project.
I would go with the Carillo, Pauter or Wossner (if available) rods. Much lighter and 20+ years newer!
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
It doesn’t take much to blow a stressed engine up – even a well built one. The more power you get the less the safety margin is – that’s just a fact of life. Any engine that sees a lot of track duty needs to be checked over often.
See my previous post – there is a good chance you have cast rods in the stock 89 engine. While they may have originally been the same strength as the sintered rods they are more susceptible to fatigue and the area around the rod near the wrist pin is weaker.
The car had a donor engine installed, all the aftermarket goodies were transferred and I enjoyed this car at a few PCA events in 2012. It runs like a top. The motor internals are all stock, with only 70k miles so should be good for some time. I just found a 996tt so will probably sell the car to any interested parties...?
