I'm Joe millionaire above 5k..... what's the deal?
<img src="http://boards.rennlist.com/upload/2d.JPG" alt=" - " />
<img src="http://boards.rennlist.com/upload/1d.JPG" alt=" - " />
<img src="http://boards.rennlist.com/upload/4d.JPG" alt=" - " />
<img src="http://boards.rennlist.com/upload/5d.JPG" alt=" - " />
<img src="http://boards.rennlist.com/upload/6d.JPG" alt=" - " />
<img src="http://boards.rennlist.com/upload/3d.JPG" alt=" - " />
<img src="http://boards.rennlist.com/upload/8d.JPG" alt=" - " />
15ish 16ish psi.....
I can also tell the BOV isn't doing it's job.
I have 3 videos so you can hear the induction noise and actually SEE the filter collapse itself! That's crap.
You went fat at 5K. You were making gobs of torque, 284ft/lbs. Carefully lean out the top end with your MAF, and you should see 280-290hp.
What wastegate are you running? Do you have a boost chart?
Lookin good. Toss up the vid so we can see it.
Since you are a rennlist member, you can post to your web space. Go to the members webs and sign up for your web space.
If your boost is rock solid from 3K-6K, then you just went fat . Lean out the high end and you should be good to go.
Luke - shoulda brought the Audi, I told you I could take you. You runnin' diesel fuel? Shoulda put some of those Morris dampers on the back, might have got another 6 horse...
