KLR MAP sensor when using external MAP sensor?
Out of curiosity.... is the KLR internal MAP sensor used for anything at all when using a Vitesse or Rogue kit with external MAP sensor?
Could it be disconnected?
/Dea
/Dea
If you are no longer using the cycling valve to control boost, then yes you can.
The dash boost gauge will no longer work!
