tech edge w-b
#47
Is anyone currently using the 1.5 techedge unit's narrowband output in place of the stock sensor signal? It would be great if I could just replace the current sensor and not have to go get the bung welded on.
#48
I think its possible with some conversion circuit that takes the wideband signal and outputs the narrowband signal.
I'm not sure who mentioned it.
I think it was in a theoretical discussion.
Danno maybe.
Danno maybe.
#49
The tech edge 1.5 unit has a narrowband simulated output already, so it appears they've done all that work for us. Just wondering if anyone has actually used it, or if I should be prepared to be That Guy who blows is car up seeing if it works
#51
I use two O2 sensors, NB and WB so I don't have to screw with the NB cable and I can remove the WB when I don't need it to extend its life.
Here is the new NAPA source for the WB:
NAPA dealer has said the OS791 sensor has been discontinued. He said the crossover/substitute number is a Bosch #13246
#53
I have been asked by several folks if I am sure this is the correct part. I am sure that it is.
One of the two sensor I was ordered using a Bosch P/N and came in a box marked Bosch # 13246, but the part inside is stamped with the NTK L1H1 which is the five wire WB required for the Tech Edge unit.
#55
Apparently the LSU-4 is a WB sensor, but at least 2 sites hint that it won't work with the TechEdge. Doe anyone know otherwise???
<a href="http://www.tragacs.com/wbo2.html" target="_blank">another website about techedge</a>
" Pls also be aware that there is a widely avaiable Bosch wide band sensor (the LSU4 sensor), but it won't work with these kits. "
<a href="http://www.techedge.com.au/vehicle/wbo2/wbntk.htm" target="_blank">TechEdge website</a>
"Here's some information from Bosch USA about their narrow band LSF-4 and their wideband LSU-4 sensor. The LSU-4 is similar in operation to the NTK L1H1 (although they are not interchangeable at all). "
#57
I doubt it'll work. The techedge people are pretty specific in mentioning the L1H1 as the one that is needed. Also, the new 2.0 version they're working on lists the LSU-4 as the sensor it uses (possibly with L1H1 support). If they're having to rev hardware to use that sensor, it's a safe guess there's enough of a difference that it's not just a drop in replacement.
#58
I have a question for you wideband guru's
I plan on adding a WB02 to my Probe, not my 944. If you feel offended by this, please don't read on
All of yoru sugegstions and info are great! I just have one quest before I go full bore.Where should i place the WBO2 in a V6 setup? eitehr front or rear bank? before turbo? after turbo? At the collector?
Any help would be appreciated.
#59
Before the turbo after the collector is fine. Or after the turbo before the cat. Collector meaning 6 INTO 1? I would love to see a pick of that exhaust plumbing.
#60
Isn't there any way of running a wb02 sensor directly to a regular A/F gauge? (not the ones with the LEDs) Or is this how it's already set up... (I know next to nothing about wb02)
