Timing belt hitting cover on engine side
Hello Everyone,
Just finshed re-seal front of engine, install new turbo and m-tune and noticed the timing belt hitting the engine cover and cant firgure out what i did wrong. Any ideas before i start taking everything apart.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Looks like an 86 with the manual tensioner. Did you remove or alter the tensioner mounting stud/nut? The flange on the backside of the tensioner gear is what sets the limit for the belt movement towards the engine.
Hey Chris,
It is an 86 and i did not modify or change anything, i tried to put everthing back the way it came out, but i did re-install everything a month later. I attached another pic if it helps to see where i might have gone wrong. Thanks again
Ah Ha… the rest of the story!
Looks like you have the TB tensioner roller and BB tensioner rollers switched.
The water pump pulley is flanged on the front side of the TB and the TB tensioner roller should have the flange on the back side of the TB.
Do – over. Sorry man.
Thanks 951saga,
I was just about to post what i did wrong. I was on clarks garage looking at pics of the procedure and noticed that they where switched, but you beat me to it! Could be worse, but glad its resolved.
Thanks everyone for the help.
