some accumulated mechanical questions
1. What are the symptoms that a power steering rack needs a rebuilt? Is it only the fact that it's leaking?
2. Fuel pump knocking on start up and small knocking in 2nd gear, 2500rpm (pressing on the fuel pedal really slowly)... do I need to change it?
3. Power steering pump: I see lots of different prices... is there a difference?
http://www.autopartsway.com/PartList..._STEERING_PUMP
what happened; one of the cir-clips that holds the wiper-bushings in place broke and allowed the wiper bushing to bind. That was awesome, the steering would go from normal to "manual steering on a semi-truck" instantaneously, without warning, and often in the middle of a turn. But no leaks..
as I said, I've never heard of anything like that before, so the typical symptoms requiring a rack rebuild are leaks. Especially at the boots.
hope all that helps.
yes, yes I do. What's even better is, I had planned all week to reseal the pump that weekend, but I hadn't planned on the excessive drinking that happened the night before, so the whole reason she did it was because I was too hung over to do it myself!
