Need advice on Tial 38mm install
Hi everyone I am excited to say I almost have my car sorted out and running well.
Here is some background.
Car is an 88 with full 3' exhaust
Rogue M-tune w 80lb injectors
Rebuilt top end
Turbonetics Turbo probably about the size of a K28 (slighly larger than stock).
I bypassed the cycling valve for the MBC install
My question is about the spring rate for the Tial. I can get a really good deal on a Tial 38 with the spring rate set at 14.7 psi (large red). Is this a good idea. My goal is to have this car around 15 sometimes up to 18 psi on boost. So would this be a wise purchase? Or should I buy one with a lower spring rating for "safety" and then turn up the boost from that.
And one other much easier question. My oil pressure light keeps coming on. I want to first diagnose the problem by changing my oil. How much oil does these 951's take. 5 quarts? more? Car is mostly a weekend warrior/fun car.
Rebuilt top end
yup - spring is pretty easy to replace. Go with whatever you want the car to run at if your boost controller fails. I went with a 1 BAR spring - with a boost controller you can set it wherever you want it - but getting a spring that won't overboost if your MBC dies on you is the one you should put in.
Spring rate on wg dictates the lowest pressure you can run. A 1 bar spring will actually be like 13.5 psi due to exhaust pressure, in my experience.
Oil is 6.9 qts on my 86
