Crossover test pipe
Crossover test pipe
I would like to replace the emissions test pipe (which connects to the crossover pipe where it goes from two to one) with a cap. Does anyone know what size this cap is. I assume it is some kind of metric pipe size, but I don't have very good physical access to the male fitting to measure.
I'm doing this so that I can reduce complexity and also remove a potential source of leaks.
Alternatively, a factory part number would be sufficient. The parts fiche does show a cap, but it does not list a part number.
TIA
'86 951
-Steve
TIA
'86 951
-Steve
I removed mine too. I don't think it helps in keeping underhood temps any lower. The cap you want is # 930.113.153.00. Since my local dealer wanted $25 for this stupid little cap, I discovered closed-end wheel lug nuts sized 14mmX1.5 fit perfectly & didn't leak.
Tom
'87 951
'86 Supra
Tom
'87 951
'86 Supra
