Arrgh - can't figure this one out
Old 06-09-2011, 01:20 PM
  #31
Racing Porsche
Racing Porsche's Avatar
Josh
What size # do you need I have a few sets.
Old 06-09-2011, 01:49 PM
  #32
Josh B
Josh B's Avatar
Originally Posted by Racing Porsche
Josh
I am using 83lbers. Had another lister offer some 72s on loan but he is out of town and I would have to adjust the FQS to use those. I was planning on going that route but if you had a closer fit that would be awesome!
Old 06-09-2011, 01:56 PM
  #33
fast951
fast951's Avatar
Josh, I have 95 but no used 83#.
John
Email
www.vitesseracing.com
Old 06-09-2011, 06:17 PM
  #34
Racing Porsche
Josh
Mine are 75 the number on the injectors is FI11445. I can get these to you anytime.
Mitch
Old 06-09-2011, 08:03 PM
  #35
Tom M'Guinn
Tom M'Guinn's Avatar
Sent you a PM with another idea. Also, Witchhunter will test and clean injectors super fast. I had mine back in less than a week, including shipping.
Old 06-10-2011, 10:58 PM
  #36
Josh B
Josh B's Avatar
Well - ran an experiement this evening with interesting results. I got a spare set of 75lb Delphi injectors from 67King for testing purposes. I installed them on the car and no stutter. There is a slight single hiccup at around 5200 RPM that showed up after a few runs - might be those solid core wires though. I am thinking I need to track some some new injectors and get some Clewitt twisted core plug wires from Pelican. Also am planning on installing the resistors for the injectors as I don't think those were ever put on this car.
Wonder if I should go back with Siemens injectors or try something else?
Old 06-10-2011, 11:09 PM
  #37
thingo
thingo's Avatar
Can't you use something like id 1000's? Yes they cost a lot more but the total outlay is not huge.
Old 06-13-2011, 12:39 AM
  #38
IMB951
IMB951's Avatar
Glad your issue is getting better, Josh. My 951 just acquired a somewhat similar problem. Mine's got a massive hesitation through the entire boost range at WOT, not an RPM-specific stutter like you had. Also suddenly running obscenely rich at idle and part throttle
Any suggestions are appreciated: https://rennlist.com/forums/944-turb...ml#post8632241
Old 06-24-2011, 10:01 AM
  #39
Josh B
Josh B's Avatar
Wrap on this issue... Bought a new set of Siemens Deka injectors and they arrived yesterday afternoon. I installed them and took the car out for a test drive. 0 issues - runs perfect all the way through the RPM range. I am planning on sending the old set to WitchHunter. I emailed them and they said they would probably be able to tell what was going on. I suspect that one injector was just shutting off completely.
As an aside I first bought a set of Delphi injectors off ebay to replace my Siemens. Upon arrival though and inspection I realized they were knockoffs or something as the build quality wasn't the same. I'll start another thread on that with pics.
Old 06-24-2011, 10:28 AM
  #40
kinglenario
kinglenario's Avatar
hey chris, nice work buddy! you hit the nail right on the head with the injector issue .
Old 06-24-2011, 11:00 AM
  #41
ilikemy944
Going with the pack
is quite monotonous.
ilikemy944's Avatar
BACK to the DYNO!!!
Old 06-24-2011, 11:02 AM
  #42
Josh B
Josh B's Avatar
Originally Posted by ilikemy944
BACK to the DYNO!!!
You need to drive this car again with the sticked Kuhmos on it Hello E-85 here I come!!
Old 06-24-2011, 03:20 PM
  #43
IMB951
IMB951's Avatar
We gotta meet up again soon. I need to get in on this E-85 business amongst other things (such as getting another ride at more than 10psi)
Old 06-24-2011, 06:10 PM
  #44
ChrisJ951
ChrisJ951's Avatar
Josh- I need a ride in this beast.
Old 06-24-2011, 11:01 PM
  #45
Tom M'Guinn
Do I get a prize for guessing right on the first try?
Quick Reply: Arrgh - can't figure this one out
