Bigger injectors..
Bigger injectors..
Does anyone know whether you can put 968 injectors on the 944 turbo (1987 model).
I gather that bigger injectors are one thing thats needed to gain hp.
Has anyone put bigger injectors in, where can you get them etc.
Is 2nd hand 968 injectors a good idea or not?
I dont know if 968 injectors would fit or if they would be a good upgrade. You are better off buying the 55lb upgrade injectors from <a href="http://www.gururacing.net" target="_blank">www.gururacing.net</a> and getting a set of chips from there as well. They have great prices and customer support. HTH
you can't just put bigger injectors on a stock car and have them work, you need to have chips that support them. like mark944turbo said, guru racing has the appropriate chips and injectors.
From what I have been told, stock injectors are fine up to around the 300 rwhp mark, then you need to go larger.
I also agree with the above on Guru Racing
