Can anyone tell me if this is correct
I am trying to chase down my no oil pressure issue. Is there suppose to be a gap that big from the sprocket to the oil pump housing/cover?
![](http://i24.photobucket.com/albums/c47/porsche951/9ca3a503.jpg)
I would say yes… you don’t have the rear belt cover in place so it looks as though it’s further out. There should be the one spacer/ washer between the crank pulley and OP drive gear.
Also if your TB is tracking correctly when spinning the motor, you know its right.
Basic Sponsor
I can't see if there is a washer there, but there should be one
Basic Sponsor
I told you it helps to fill the engine with oil, can't have pressure without it
