Need Help With Boost Controler Install
I am installing a Greddy Profec A. It comes with a little box with one large boost line fitting on one side and two large and one small boostline fitting on the other side. I am also going from a stock wasgate to a delta gate. What do I do? On the back of the Profec A controler ther is a setting that you can set for: Actuator Typ, Actuator Typ (when over boost acures), External Wasgate(off set: -50%~+50%), and External wastgate (Offset: -100%~+100%). What position should this be in?
thanks All
thanks All
Chris,
I can help with the wastegate, but know nothing about the Profec A.
Boost line from intercooler pipe run back to the firewall put in a T joint, one line goes to the Deltagate boost port the other side of this T joint will go to the in port of the controller.
The vacuum port on the Deltagate will have a line that connects to the regulated boost line from the controller.
Hope this helps
Hope this helps
