Engine dead :(
Old 05-23-2011, 09:35 PM
Mark-87-951
Mark-87-951's Avatar
Default Engine dead :(
Car ran fine yesterday and today on the highway after finishing the water pump work and front reseal, new rollers, new belts work this weekend. Unfortunately as I'm nearing home I hear a puff and then a sound that makes me think a hose popped loose. I drive it slowly the next few blocks and get in the garage and as I go to turn it off the engine dies. I think I heard a rattle but Ive been hearing one from under the car every now and then lately so not sure if this was new, though it probably was a worst case from what I've been reading.
The engine spins freely now when I tried to crank. I think it may have spun freely as it died but not sure exactly what I heard now.
I'm figuring that the new belt failed or something along those lines and valves hit pistons. I'm going to inspect the belt tonight and see if that is damaged.
If the valves bent, what's a general price range on the work? I've r&r the head before so I can save on that cost. Would it be better just to get a complete new cylinder head? One problem is that I have to rent a car while this is being done so turn around is a potential deciding issue.
Old 05-23-2011, 10:14 PM
plumbum
plumbum's Avatar
Definatly want to pop the covers off and have a look. Hopfully it is something easy that just came unplugged...sensor..coil ect
Old 05-23-2011, 10:22 PM
User 52121
User 52121's Avatar
Your description leads me to think it could be a popped boost hose (or a tear in one of the couplers.)
Old 05-23-2011, 10:32 PM
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
+1. Having done that A LOT lately, that's what I would bet too.
Old 05-23-2011, 10:50 PM
Tom M'Guinn
Tom M'Guinn's Avatar
Boost hose was my first thought too...
Darwantae951
Darwantae951's Avatar
Peak thru the cam TDC hole to see if the belt is still intact. If a boost coupler pops off, the engine really doesn't want to run and will die (happened to me a few times...)
Old 05-23-2011, 11:31 PM
Mark-87-951
A boost hose popping off would have been a nice revelation but sadly very slim. I have t-bolts and silicon couplers and my inspection so far is depressing.
Got the top belt cover off. Balance belt shredded but enough still intact to engage the shafts and turn them. Timing belt slipped off tension sprocket, will have to remove the bottom cover and see if any teeth missing but what i can see they are still intact. Balance shaft sprockets front plate are damaged from the incident.
I'll post pictures in a moment. I'm thinking I should start pulling the head tomorow night and see how many valves kissed the pistons.
Old 05-23-2011, 11:40 PM
Mark-87-951
What I've found so far
Looks like flickr doesnt allow embedding anymore. Here is a link to a set of camera phone pics
http://www.flickr.com/photos/1422638...136084/detail/
Old 05-24-2011, 12:09 AM
User 41221
User 41221's Avatar
Gack! Any idea what caused that? Loose belt tensioner perhaps, and then when teh timing belt slipped, it took the balance shaft belt out?
The good news is that if you did the belts yourself, pulling the head isn't beyond your abilities, just work slow and you'll do fine. Any local machine shop should be able to take care of teh head work and it won't be that expensive, relatively speaking.
By the way, I have a brand new head gasket kit sitting on the bench unopened, if you need it. You can have it for my cost, $132.00 shipped.
Old 05-24-2011, 12:19 AM
Mark-87-951
I've pulled the head off before when the gasket failed several years ago. I did that in my apt. parking lot but now I have a garage I can use so much more convenient. I had some valve springs that were bad and valve guides as well. I'll keep the gasket kit in mind. I've got some research to do on where I took the head before and such.
Old 05-24-2011, 12:20 AM
Mark-87-951
The tensioner seemed fine, I'll mess around more over the next few days and see if I can figure out the cause. Would like to avoid a repeat.
Old 05-24-2011, 12:21 AM
Mark-87-951
Ok, the previous work I had done on the head was:
Cylinder head resurface, valve job, new springs
$488.16
That was in 2005
Old 05-24-2011, 12:35 AM
schip43
schip43's Avatar
Well $280 for labor on a DOHC 16 Valve 2 liter in Carson City NV, plus parts ie 16 valves. Times 2 in my case, I had a roller failure and there was still shrapnel, I did not see when I redid the head and T-Belt. Yjis time it only bent all 8 intake valves.
My point being triple check to make sure you get all the crap out of there!
Old 05-24-2011, 12:39 AM
Mark-87-951
Any opinions on the Lindsey Racing Stage I cylinder head as far as value? If I have to replace a large number of valves maybe it's a better deal?
I guess it's a good thing I have the lindsey metal gasket for the cam tower, I can reuse that.
Old 05-24-2011, 12:40 AM
Mark-87-951
I hope the rollers are still good. They are all new.
Quick Reply: Engine dead :(
