Part number?
Part number?
I am looking for the part number of the plastic zip tie things that hold the wires and such up against the firewall and other places, they screw onto a stud coming out of the firewall.
Thanks,
<img border="0" title="" alt="[Wink]" src="wink.gif" /> <img border="0" alt="[cherrsagai]" title="" src="graemlins/drink.gif" />
Thanks,
They are expensive! The part doesn't have a release catch and every time you need to remove a part from the bundle you have to cut these expensive parts. Iceshark was able to talk a company in Germany out of some samples, but they had a large min order requirement.
Here is a cheap, reliable solution to the problem. You take off the original piece and cut off the tie wrap section. Then you put this plastic part
<img src="http://boards.rennlist.com/upload/Clip1.JPG" alt=" - " />
over the stud and then push the original part back on the post. Now you can use regular tie wraps to secure the wire and you only need to cut the tie wrap, not the fastener, when you need to add wire to the bundle.
<img src="http://boards.rennlist.com/upload/Clip2.JPG" alt=" - " />
