Vitesse MAP sensor, different transfer functions in documentation?
Preparing for start-up next week and when setting up the piggyback I noticed that the MAP transfer function values that are supplied on the MAP document differs from the values shown in PB screen pictures in the Boost control documentation.
I guess I should use the values in the MAP documentation?
/Dea
/Dea
Thanks!
I had some issues with the sensor calibration, I thought that if I for example want to calibrate it for use up to 17psi I would simply put in the 17psi and the corresponding voltage on the highest position and 0psi and the corresponding voltage on position 0 but for some reason it does not accept the input 0psi on position 0?
/Dea
/Dea
