which is correct 87 951 front strut?
i ordered up paragon coil over set up and today when removing the struts this is what I found out
the lower strut has the part number 11 1500 100 640 and 944.343.032.1 cant make out last number.
I was to know which is the correct strut to use for my 87 951 coil over kit. so inother words s2 strut.
the lower strut came with long spring and 2 white dots and the top strut came with short springs and 3 white dots.
little reseach tells me the lower strut is correct and part number 944.343.032 should be 87 right side strut.
can someone please confirm. in which case I need to now find a junk strut. does it have to be left side? or does it not matter since I am installing the coil overs
