'86 Turbo front wheel hub failure
Hi Guys,
We were running in Hallett, OK yesterday for the Porsche DE and our front right wheel hub broke.
![Name: photo.JPG
Size: 125.9 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/532828d1304251331-86-turbo-front-wheel-hub-failure-photo.jpg)
Hopefully, things did not get "catastrophic", everything stayed together. Just a big pop and lots of vibrations and the right brake was grabbing in turns.
I have been searching around if this is a common failure or not. It does not seem to be. Anybody has a take on it?
Does anyone has one or two spare front wheel hubs for an '86 944 turbo laying around for sale?
Or is there a recommended conversion for those as they seem to be a one year only installation?
Thanks for your help.
![Name: photo.JPG
![Name: IMG_5206.JPG
Size: 53.0 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/532831d1304251968-86-turbo-front-wheel-hub-failure-img_5206.jpg)
Rennlist Lifetime Member
It is a fairly common failure..especially in race cars. I'm glad your failure didn't result in anything catastrophic. I had 2 failures & then gave up on the OEM wheel hubs. I've replaced them with the Racers Edge billet hubs - they've been perfect for 3+ years. I highly recommend them.
Rick
Rick
What size tires are you guys running?
I'm not going to argue that it isn't common, but there has to be a common link as to why this happens.... To much camber, wide tires, stiff springs, etc...
The 87 and newer hubs are stronger and are a common update for the 86. Lots of post on how to do this update since it changes the wheel offset. The change in offset opens up the door to a large selection of wheels.
Very common. The later ones, including the M030 hubs are falling apart as well. Years of use on an aluminum hub is going to lead to failure eventually.
Rick
Rick
Wide Tires: yes, 225/50-17 on Nardi by Speedlines on slicks
Stiff Springs: you bet... 500lbs
That's the info I needed ! Thanks guys. I will dig for posts on that conversion. This is probably what I need to do. If anybody knows a DIY post on the conversion, I welcome any link
Thank you guys for all your help, I appreciate it.
Am just back from Hallett, car is back in the garage. Hopefully, I have a few weeks ahead of me to fix it.
Good to know it is a common failure. That means I have to take actions for a permanent fix or it will happen again. This car has a LOT of grip, so I am sure those hubs are taking a pounding...
I've seen those at Racers Edge but they advertise them for 88 turbo and above. Am not sure it works on an '86 turbo. Different spindle, bearings and hub... I will call them tomorrow and check with them.
Camber: about 3 degrees in the front
Wide Tires: yes, 225/50-17 on Nardi by Speedlines on slicks![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Stiff Springs: you bet... 500lbs![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
but I will search.
It's very simple, unbolt the ball joint end, pop off the tie rod, unbolt the strut, remove caliper, remove 86' spindle/hub assembly and replace with 87'+ spindle/hub assembly. Like mentioned, apparently you lose a bit of camber adjustment but this shouldn't be a problem with camber plates.
Rick
Rick
Hey Doc Karl, how are you? Remember me, I sent John Adrien over to you for that PPI on a black 993. His car is doing well BTW, and he is enjoying it.
Hey Benoit! Glad to hear the car is doing great and he is enjoying it! You can't go wrong with a 993
