Stutter/jerk when I let off in boost
When I'm in boost and let off, the car jerks/stutters. It does it in between shifts too.
I suspect the bypass valve is toast, causing compressor surge. Could this also be caused by a bad clutch?
Because I come off the accelerator peddle before I disengage the clutch.. The short moment of throttle being closed the car decelerates violently for short bursts.. ie compressor surge. However I have heard elsewhere that this could also be the clutch, (driveline backlash). Has anyone had this problem?
I'm going to be replacing the bpv with a billet unit to handle the boost
