ihaza944t, are you suggesting that this was a bad idea? I was toying with this notion as well...it is the cheapest of options.
Great advice! Thanks guys! We have no emissions testing, so I'm not too worried about the cat remaining in tact.
Not at all, once you see what's in there you'll realize how much of a restriction it is. But apparently the hollow chamber creates turbulence or something, that's what I was told on here anyway. A test pipe would be better.
If you do go that route, good luck! I attached a hole saw on a 4 foot drill extension and went at it for about half an hour probably more
