Bosch HV fuel pump direct fit?! Ha!
And that link makes no mention of the fact that the HV pump has a larger barb on it than stock, making it nearly impossible to put into the stock hose from the fuel tank.
Don't know about the 928GTS pump or what it's rated at.
Well, went out these this morning with my neighbor. I grabbed the hose to show him what I wanted him to do and the damn thing slid all the way into place! Course the factory hose clamp was too small, so I had to make a quick run to the hardware store for another larger one, but the job is done!
Car is back on the ground and it does run and as a bonus it isn't leaking fuel, so all the connections are tight.
The Walbro cost and spec looks really good. Did you change any of the wiring to the pump? I see it is rated at around 10 amps at 3 bar pressure. Not sure what the factory unit current draw is put I can check it. I am running E85 and though getting a bigger capacity pump was in order. I just ordered a install kit with the pump for $110....great price.
1 Post
Walbro is junk you get what you pay for it is no match for a 044 especially at elavated fuel pressure. Saving a hundred bucks but blowing a ten grand motor....Rennlist FTW.
Agreed, the 044 spec is much better then the Walbro at elevated pressures and flow rates. I am running E85 so will need about a 30% flow rate increase. So far, the stock pump is doing the job. So, is this a specification issue or a product reliability issues? My search did show up any product issue with the Walbro. Is there one??
1 Post
The Walbro just fails, hands on experience, if you open one up they are made like a plastic toy. Are they rated for E85 ? Even Bosch rerates the 044 for E85 use.
Anyway I would never use the Walbro for E85, that is going to be guaranteed instafail IMO.
I have run a Walbro GSL-392 pump in my 951 since 2004 without any problems and without changes in the electrical system (maybe I changed the terminal size for better fitment). I do run the OEM 2.5 bar FPR.
Last year I installed an identical pump in my Espada, which had been sitting too long with the gas being converted to tar, gumming up the Bosch pump. The Walbro pump started out being noisy (whining), but got quiet after some hours of running. I assign the noise to inadequate fuel system cleaning, rather than a temporary defect in the pump. Here I run a 3 bar FPR.
Laust
PS I do not know about E85 compatibility.
Hi Brian,
Laust
Laust
To the person that asked if you need to do anything to the wiring, yes you do. A simple snip and crimp job on the two terminals. The posts on the Walbro are slightly larger in diameter to what is originally on the car. The fittings to do this were all in the install kit. The pump says to install a 20A fuse, but i think the wiring is too small to run 20A through so I left the stock 15A one in there. Looking at the Flow/Current graph, around 3Bar it's ~8A. 15Amps is equal to 110Psi and 65GPH, which is more flow than I will ever need.
