clutch/driveline chatter
I am a new 951 owner and am experiencing some clutch/driveline chatter starting off in first and when I downshift to second....the car only has 33K miles on it so I am assuming the clutch is not worn.
I am going to change the brake fluid and bleed the brakes this weekend....do I need to bleed the clutch as well?
Any other possible adjustments I can make or any other ideas on what may be causing the problem.
Thanks in advance for the help.
