How to remove Oil Filter ?
Old 04-20-2011, 10:24 AM
  #61
Zeff
Zeff's Avatar
About the gauges - the gas needle not going to 4/4 is common, are any other gauges acting funny or just the oil pressure?
Old 04-20-2011, 10:25 AM
  #62
Zeff
Zeff's Avatar
Originally Posted by Tedro951
The higher the resistance (senders job), the higher the oil pressure. If you disconnect the wire(s) it would probably read 500 bar oil pressure if the gauge went that high.
Clarks has a section on testing sensors, but it uses a potentiometer, which I'm guessing you don't have. If it was mine, I'd have someone watch the gauge while you hold the blue/white wire against the block or the side of the sender.
What made you want to switch the wires?
Could too much oil keep the gauge pegged also?
Old 04-20-2011, 10:29 AM
  #63
Tedro951
Tedro951's Avatar
15 quarts wont change the resistance of the pressure gauge.
If you're on a budget, get a used sender and put it on. You've already removed the wires, so you're halfway home.
Old 04-20-2011, 12:19 PM
  #64
ali4
ali4's Avatar
I ordered a sender from Pelican parts it should be here tomorrow. I am more worried about getting it off I had NO space to work down there i couldn't even get the wire clamp bolts off. I found some instructions on how to do the job and it seems straight forward but I cant figure out how I will unbolt that sender and re bolt the new one in such a tight space. May need some special tools.
Old 04-20-2011, 12:21 PM
  #65
ali4
ali4's Avatar
Zeff - My guages seem to be working fine except the gas and pressure. I also have a bunch of lights on...
Old 04-20-2011, 12:32 PM
  #66
Tedro951
Tedro951's Avatar
Did you find the instructions on Clarks Garage?
Old 04-20-2011, 03:44 PM
  #67
joster86turbo
joster86turbo's Avatar
it's pretty easy with a 15/16 stubby wrench. NOTE: the "stubby" part is the key.
Old 04-21-2011, 11:57 PM
  #68
ali4
ali4's Avatar
Hey everyone - I got my first oil change completed successfully (so far).
-Sealed up the tiny hairline crack in the oil pan with a few layers of JB Weld.
-Also got the old oil pressure sender replaced with a new one and the pressure is being read correctly.
Could not have been done without the help from everyone on this board!
Thank you all very much!
(Now I will be trying to drain my coolant and change the auxiliary turbo cooling pump, and thermoswitch I have another thread where I am getting some help on that, feel free to drop some pointers)
Old 04-22-2011, 12:00 AM
  #69
Bri Bro
Bri Bro's Avatar
Just to be sure you are on the up and up, post pictures of your car and the repairs in progress. Lots of jokers out there. All oil pans have casting marks that look like cracks. That seems strange to me that you would glue them.
Old 04-22-2011, 12:31 AM
  #70
pontifex4
pontifex4's Avatar
*cough, cough*
I just gave this a read through, and it did actually teach me a couple of things. I didn't really spend a lot of time working on cars growing up, and having this kind of thing around now and then actually keeps me from needing to ask dumb questions. Thanks, Rennlist!
Old 04-22-2011, 12:35 AM
  #71
Bri Bro
Bri Bro's Avatar
That was what got me thinking...and there are more out there.
Old 04-22-2011, 12:37 AM
  #72
pontifex4
pontifex4's Avatar
You mean, we're not alone?
Uh oh.
Old 04-22-2011, 01:13 AM
  #73
reno808
reno808's Avatar
Why would you put JB weld on a crack oil pan?? here let me help you replace your oil pan. Google Clarks-garage that's would be you Ur new best friend. I can send you a copy of the service manual if u want.
Old 04-22-2011, 02:07 AM
  #74
Bri Bro
Bri Bro's Avatar
Uh oh.
Yup
Old 04-22-2011, 03:04 AM
  #75
ali4
ali4's Avatar
I was driving over a speed bump and it grinded the bottom of the oil pan after that it started to seep a little bit of oil a few drops a day. When I got under the car I could see where it scraped the pan and I found the oil was coming from a small crack which had formed. I decided to JB Weld it for a temporary fix. I'll see how long it holds up.
Reno what manual would you send me? I have the 300+ page workshop manual if thats what you were talking about.
Quick Reply: How to remove Oil Filter ?
