Check engine light!!!! Please help
Does anyone know if the "check engine" on the center console is used on the 944 turbo. I just removed the instrument cluster and all three bulbs have either been removed or the instrument cluster is used on other models. All of the other guages work and so does the large red exclamation point light. do turbos use the light that specifically says "check engine"
thank you
Jeff
thank you
Jeff
