Random weird start
Hi guys, I know theres a tons of post like this one on many forums. I tried to read more than I can but no solved solutions.
Sometimes when I start the car (cold, warm or hot), the car start perfectly or cranks. Never the same, sometimes it crank 2 times, sometimes 5 times, sometimes slowly 3 times..
Is someone had the same problem as me?? I need an solved solution with a problem like mine.![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
This was happening on my old 1986 NON-Turbo and on my current 951 1988. I know that A KIT of Porsche 944 have this problem.. there must be a solution no..?![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
Oh my batterie is new. To help you here is a list of changed parts on my car, if this can help but the problem was there before any modifications.
Porsche 944 Turbo 1988
Body:
• Ext color: Graphite Black
• Int color: Black leather
Engine:
• 2.7L
• Pistons J&E 102mm
• Steel sleeve
• Head engine rebuilt
• Roller & Belts
• All the seals changed
• Headers in perfect conditions
• 10 000km
Tuning [Give 305HP & 350LBS Torque]:
• LR/951MAX Chips
• Lindsey Dual Port Wastegate
• Lindsey Manual Boost Controller
• 3 Bar Fuel Pressure Regulator
Insulation of:
• Headers
• Downpipe
• Turbo
• Crossover Pipe
Suspension:
• Rear new Bilstein Firehawk shocks
• Front new stock shocks
• 968 Caster Blocks
Other:
• New Blow Off Valve from a 993
• Injectors cleaned and new seals
• Turbo K26/8 rebuilt by Bramall
• New Vacuum & Preston tubes
• New Vacuum & Preston & Intake hoses
• Ball joint rebuilt
• New suspension bushings
• All fluids changed
• Air/Fuel meter
• Rack rebuilt
• Kenwood CD Player
• New starter
• New battery
• New clutch
• New Air Conditioning Compressor (New Standard)
Wheels:
• 17" Twist Turbo Wheels
• Front: 205
• Rear: 255
• Colored center cap
• Caliper rebuilt
• PBR Brake pads
Thanks!
Body:
Engine:
• 2.7L
• Pistons J&E 102mm
• Steel sleeve
• Roller & Belts
• 10 000km
• LR/951MAX Chips
Insulation of:
• Headers
• Downpipe
• Turbo
• Crossover Pipe
Suspension:
• 968 Caster Blocks
Other:
• Air/Fuel meter
• Rack rebuilt
• Kenwood CD Player
• New starter
• New battery
• New clutch
Wheels:
• Front: 205
• Rear: 255
• Caliper rebuilt
• PBR Brake pads
Thanks!
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
I'd suspect the s/r sensors. Every time intermitant problems happen it seems to be them. I had one of the bolts strip out and it would randomly not start. Those are the only things I've had trouble with regarding random non starts.
Yep I would say the speed and ref sensors, look for tach bounce! If the tach moves it will start if no tach bounce it won't!
I have replaced both sensors and it still does it! No real pattern happens at random, I shine a flash light on the sensors barely touch the wires and it fires right up!
Those freaking sensors are the best argument for a Standalone with a crank mounted trigger wheel in my opinion!
But hey it's part of the charm!
Body:
Engine:
• 2.7L
• Pistons J&E 102mm
• Steel sleeve
• Roller & Belts
• 10 000km
• LR/951MAX Chips
Insulation of:
• Headers
• Downpipe
• Turbo
• Crossover Pipe
Suspension:
• 968 Caster Blocks
Other:
• Air/Fuel meter
• Rack rebuilt
• Kenwood CD Player
• New starter
• New battery
• New clutch
Wheels:
• Front: 205
• Rear: 255
• Caliper rebuilt
• PBR Brake pads
Thanks!![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Body:
Engine:
• 2.7L
• Pistons J&E 102mm
• Steel sleeve
• Roller & Belts
• 10 000km
• LR/951MAX Chips
Insulation of:
• Headers
• Downpipe
• Turbo
• Crossover Pipe
Suspension:
• 968 Caster Blocks
Other:
• Air/Fuel meter
• Rack rebuilt
• Kenwood CD Player
• New starter
• New battery
• New clutch
Wheels:
• Front: 205
• Rear: 255
• Caliper rebuilt
• PBR Brake pads
Thanks!
good luck,
Jason
Are you saying sometimes the car cranks slowly, sometimes at normal speed?
If so, clean the the major grounds and the connections on the starter and battery.
Ditto to Jerome - what's "slowly"... the cranking, or the car running?
If it's a slow crank, then do what Jerome said - check all your battery and starter electrical connections.
If it runs slowly (3-400rpm and then creeps UP to idle) - my car did the same thing (you bumped up my old thread, I responded there too.) Hard warm starts where I had to crank the hell out of it to start, it would sometimes "spring" to life, and other times, it would start slowly - as in, run at 3-400rpm and work its way up to idle speed of 850. That turned out to be a sticky AFM. You can pull yours out and take a look inside. The flapper door should move cleanly and freely all the way through its stroke. If it binds or sticks in ANY way, then you probably should think about replacing it as that's probably the problem.
I'd also try what Grandpa #3 said and blown 944 referenced - jiggle the reference sensor wires. In fact do this first before looking @ the AFM as this is much more common. Easy way to tell if it's a reference sensor issue: you should see the tach bounce when you crank it. If the tach isn't moving at all, then jiggle the reference sensor wires and try again. If the tach IS bouncing a little, then the sensors are doing their job and you need to look elsewhere.
Ok thank you guys for your answers.
For the battery cables, no dirt there.
Major ground.. can be interesting to take a look there. I will need to find it.
When the weather will get warmer outside, I will take a look the the R/S sensor cable. If the cable is clean, i'll take a look with the tach (tachometer?? this is what we are talking about??) Because I dont know what this piece looks like (R/S) so i cant figure out what is the use of the Tach. Thanks to explina me.
I'm pretty sure the problem is from the Reference crank or speed sensor
Thanks guys.
Thanks guys.
Ok thank you very much sir! Imma take a look soon!
And you it solved your problem?
And i want to say to all ppl that my car ALWAYS start. Because so said if your car won't start. He always start
Hmm interesting. It makes me wonder how many bad AFM's are out there? I have the random non start after hot and wiggle wire and it start thing also. This after new sensor reference wires were rtplaced!
I'd be curious if anyone that had this problem found that it disappeared after a MAF install?
