3" Catback Turbo Spools Slower
#33
can't blame ya for trying...
Well I took the car for a drive this morning and got into Wot in first gear which to my shock actually got 10psi, which it usually is. I think getting that huge leak fixed at the muffler helped a lot. I checked for vac leaks and I'm good. I check the front of the exhaust and everything appears to be fine. So once the other minor leaks are fixed I should be good.
#35
#36
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I think the problem is that your car is upside down. Put it back right side up and it will run better.
Seriously folks – back pressure on the exhaust side of the turbo will not make it spool faster – and leaks on the exhaust side will not make it boost less or slower.
However – welding on the car exhaust while connect to the engine without discontenting the battery may annoy the hell out of your electronics!
#39
#42
I'm going to check for exhaust and boost leaks to make sure, if not then it's just simply like what Fastrax said... I already found one decent exhaust leak right at the weld for the muffler inlet, I got that fixed but it's still a little slow on spool. I think I got a few RPM's back lol.
Nope it's an NA with a leafblower taped to the intake
#43
Just joking of course. For a more helpful response, re-read Chris W's post. He is right.
(And, just in case it comes up again, the earth is not a disk sitting on the backs of huge elephants).
#44
Cyclone: the only way i know how to check for exhaust leaks is to run some sea foam through a vacuum line. This produces alot of smoke and may make your engine run rough through the process but it is good at making leaks obvious.
Any one have any better solutions?
#45
