PWR STEERING PUMP CHANGE
Drive-by provocation guy
I am changing out my bad pwr steering pump and was wondering if there is anything that I should watch for or any inside tips. Looks pretty straight fwd. Just thought I would ask anyways. <img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
Flush the system and use Dextron III ATF for fluid. If you have any leaking/weeping now, change the reservoir and go to the updated supply hose and fitting (barbed instead if the banjo). I got my OEM (ZF) reservoir from <a href="http://www.thepartsbin.com" target="_blank">www.thepartsbin.com</a> and PCNA had them backordered from Germany. Cheaper too! Just not in a Porsche labeled box.
Mike
Mike
